Do those extended terminals just unbolt and remove?I bought an el-cheapo from fleabay like BeeBeep
Remove the extension terminal, cut about 3/16" off the big stud for block clearance. Dougs Headers, 440 engine. Really spins her over!
Someone on here was selling a different extension terminal that came out the side.
View attachment 680884 View attachment 680881 View attachment 680882
This is true.. But then again they are in the junkyard for a reason..And for what all those people say that they bought for cheap. I can guarantee you you'll find one cheaper in the bone yard that will last just as long if not longer!! Good Luck
Where did you get the cover for the stud closest tobthe block?
How old is the DB? Good choice?Some where is my DB Electrics Starter, with FABO sourced Electrical post relocation kit, DEI heat bag and Doug's Headers.
Brand new, I have used them for some Motorcycles and ATV's with great success.How old is the DB? Good choice?
Used dakota starters?The 2 that I'm runnin, 1 is over 15 years old, the other about 13 and both are runnin strong.
