Is this normal? Play in lower control arm
Thats normal, when it's under a load the pivot is locked under tension...
I would think that is normal for a car with a lot of miles on it. My car had less play on one side than the other. I bought a couple of arms from a member here (that turned out to be a body arms) and they were just a little different side to side. I bought the stiffening plates from pst and welded them on my old arms, applying just a little pressure with a welding clamp, squeezing the bottom of the arms together, without impeding movement. I can’t believe that I took my parts car to the salvage yard and left the arms go with it. Found out that the car only had 71000 miles on it.
