Bill M
I tore down and rebuilt a 68 Charger recently.
I found that the drivers side front tire was rubbing the fender (on the front) slightly on a suspension travel.
Since the fender was the only part of the car not removed during the rebuild the culprit must be that the lower control arm is slightly forward. Was thinking this could only be from a K-frame or possibly the position of the shaft in the lower control arm not fully seated in the LCA.
Would be easy to see if the shaft is slightly out from seating fully in the LCA. Is the K-frame mounting holes Oval? Don't remember. I did reuse the factory bolts with the beveled seat.
Does anyone have any thoughts on this.
