Leaf Springs
djbr459
8:42 PM
Ohio
Hi All,
I'm looking at a new set of Mopar B Body rear extra heavy duty leaf springs, P4452982, same spec's. as the 440 & hemi option.
I want to put them on my 66 Coronet.
Will these springs raise the car allot? I don't mind a little but I want to keep it as lever=l as possible.
Should I look for a different set?
Thanks
Yep I put a set on my car thought the 47-year-old springs would be wore out but it didn't change the height of my car at all. Can't even tell any difference in the ride.
I just tossed those leafs in my 66 coronet. Also added add-a-leaf springs helpers and kyb shocks all around and a hotchkis rear sway bar. Zero lift.
Well when I say zero. My prior setup was the original leafs and rear air shocks pumped up.
I'll post pics later.
In the end with the combo of my parts I ended up at the same height I started at. That's ok by me. Without air in the shocks the car sat way low.
The front hangers will work
Have a set on my 66' Satellite.. Retains orig./stock ride height. Original front hanger will work as watermelon stated.
Before with air shocks at 40 psi and og leafs
New xhd leafs kyb shocks n hotchkis rear sway
Overall the lip of wheelwell opening comes about to the bottom of the white lettering on the rear tires
I can't figure which way the iPad will rotate images. My apologies
