LED Halo Ring Headlights with Parking and Flashers
71RR4406
8:44 AM
NJ
I am posting to thread because no where in the world could I find exactly what I was looking for.
If anyone was ever thinking of doing the same, I hope this helps!
I am working my 71 RR.
I wanted to have the DRL turn off, and Amber on with Parking, Flash with turn or Hazards, turn back to DRL when Headlights are on, and still flash Amber on turn.
So it took some time, a few ideas from others and put this mess together. Now it was not easy and there are many relays involved, but I was able to hide them in the fender wells behind the headlights.
I also took time out to make a harness so I did not have to cut into the factory wiring. I purchased one for the Headlights and just had to modify for the dual lamps. The lights i purchased actually comes with the extra pig tails. I then made one for the relays, flashers, front markers and DRLs. It took a bit to get it all straight, but ended up only cutting the wire for the marker lights on each side.
I have installed full LED with DRL and Amber Turn. I picked them up on E-Bay for less than 100 with shipping. The ones I purchased only needed a small nob on the back taken off. No mods to the buckets or original wiring.
I have the DRL set for Running power. Next I am actully going to look into a vacuum actuator so they only turn on when the engine is running.
When the turn signals or hazards are enabled, the DRL will turn off and then flash amber. Upon turning off, DRL resumes.
When Parking Lights are turned on, the White DRL will turn off.
The turn signals and hazards work the same as above. The amber parking lights will turn off and then flash. Upon turning off flasher, DRL resumes.
When the headlights are turned on the parking light will disable and the DRL will resume. When the Turn signal or hazards are enabled, the DRL will turn off and then flash amber. Upon turning off flasher, DRL resumes.
Headlights will stay on during the turn signal at night.
I am in NJ, this is legal, and can not see why it is not legal in any state. I have them working basically the same as my 2022 Dodge Durango R/T.
The next step is to potentially add two more relays to have the front marker lights flash on turn as well.
I have also changed every bulb in the car to LED.
I will post some final pictures once it is back together.
There is one caveat when activating the High Beams, but you can insert an optional relay to take care of that.
FYI make sure you change your Flashers to No Load Flashers compatible with LED.
I converted my Front Markers to Flashers as well for looks and safety.
I think I have the diagrams correct, but if you find something off, let me know and I can correct them.
I have to put everything back together, take some photos and videos. I will post them soon.
Design below is excluding the front marker lights with the optional high beams.
You will need seven (7) standard change over relays, 5 pin Bosch style and two 2 (2) delay off 5 pin Bosch style.
Below is actually what i ended up with.
Design below is including the front marker lights with the optional high beams.
You will need nine (9) standard change over relays, 5 pin Bosch style and two (2) delay off 5 pin Bosch style relays.
My parts list below​
4PCS 5-3/4" 5.75" Inch Projector LED Headlights Sealed Beam Halo Ring Lamp Bulbs​
4PCS 5-3/4" 5.75" Inch Projector LED Headlights Sealed Beam Halo Ring Lamp Bulbs | eBay
Niligh 5pcs Waterproof 40/30 AMP 12 AWG Tinned Copper Wires Relay & Harness Set​
Niligh 5pcs Waterproof 40/30 AMP 12 AWG Tinned Copper Wires Relay & Harness Set 812227032197 | eBay
US Location H4 Headlamp Light Bulb Ceramic Socket Plug Relay Wiring Harness Kit​
US Location H4 Headlamp Light Bulb Ceramic Socket Plug Relay Wiring Harness Kit | eBay
Accele BU-509TD 30 Amp Programmable Time Delay Relay with adjustable Timing Off​
Accele BU-509TD 30 Amp Programmable Time Delay Relay with adjustable Timing Off | eBay
DRL ... daytime running lights? What is P/F?
Do those headlights have a separate bulb for daytime running lights or do they use the "low" beam? When you use a turn signal, do both halos blink or just one?
I just read the specs on the headlights - I see they incorporate a separate amber turn signal. I have a set with halos but they're just headlights with a halo - no turn signal. I want to use a halo as a turn signal - wondering if one or both should flash.
Parking / Flasher.
These have Day white light and amber.
If you just hook up to stock, and no relay, the amber will flash on turn and white halo always on.
Buy the Harness, plug and play, direct power feed to battery with fuse and 2 relays included.
I wired mine for both halo to blink on each side.
I was going to do single, but it looks cooler with them both flashing, and then adding the Marker Light.
You can pretty much wire these anyway you like. I was going to only amber the inners until High Beam, but i decided to have all 4 lights be high and low.
'69 RR ... no bulbs in markers.
Am I correct in assuming you wouldn't want the halos on when the headlights are on ?
You can leave the white Halo on with Headlights, its fine, looks better and legal.
I still flash the amber with headlights on.
I do not have amber parking halo with headlights.
In progress.
You can see the nub that has to be removed.
On-coming drivers must love you !!!
As long as they are adjusted correctly, they are really no worst than any of those german cars!
They can see you coming!
See item circled in green - per your diagram pin 87 is jumpered to pin 85. Is this correct ??
sorry, yellow should be on 87a only
One thing i had to do for all of the LEDs to flash correctly after installing both LED flashers with the ground, was to swap the positive and negative wires in the plug.
Only it doesn't work normally.
I think this is the rest of the parts and bulbs i used.
Yoper BA9S 53 57 1895 64111 LED Light Bulb for Car 12V White https://a.co/d/6LadjA7
VehiCode 12V/24V Blue 1156 Mini LED Light Bulb Kit 1141 7506 1003 5008 67 89 P21W BA15S Single Contact for RV Camper Marine Boat Porch Utility Interior Dome Puck Outdoor Malibu Landscape Lamp (2 Pack) https://a.co/d/5vPbHgm
VehiCode 1157 LED Bulb Red Light Bright Kit 2357 2057 7528 1157A 1034 P21/5W BAY15D Dual Function Replacement with Projector for Car Motorcycle Rear Turn Signal Tail Brake Stop Light Lamp (2 Pack) https://a.co/d/363eFa6
VehiCode 1157 LED Bulb Amber Yellow Light 3000K Bright Kit - 2357 2057 7528 1157A 1034 P21/5W BAY15D Dual Contact Function Replacement for Car Motorcycle Turn Signal Light Blinker Lamps (2 Pack) https://a.co/d/aYFoDYX
VehiCode 1156 LED Bulb White Super Bright Kit 12V-24V 7506 93 P21W 1073 3497 BA15S Single Contact Replacement with Projector for Car Automotive Reverse Backup DRL Lawn Mower Headlight (2 Pack) https://a.co/d/cRuErWx
BRISHINE 4PCS BA15D 1142 Interior LED Light Bulbs for RV, Super Bright 4500K Natural White 1004 1076 1130 1176 LED Bulbs for Camper Trailer Marine Boat 5th Wheels Motorhome Indoor Lights(12V-24V DC) https://a.co/d/5iaFVXg
Makergroup 158 LED Bulb W5W 2825 168 192 194 T10 Wedge Light Bulbs 12V Cool White for Car Side Marker Lights Dome Map Door Courtesy License Plate 0.5W 10-Pack https://a.co/d/fAir7vm
https://www.napaonline.com/en/p/NF_EL12L1
