lets see your kill switches!
dangina
1:53 PM
lethbridge
looking at moving the battery to the back on my 71 runner - where did you guys mount your kill switches? Lets see them pics!
in the bumper on the roadrunner
under the bumper on the dart
Mine is not built yet but here's what I plan. NHRA says if it's a push pull switch, it must be pushed for "off." FINE
I'm going to build a rod to actuate the switch, which is a sliding sleeve over the top of a rod. In other words, you can push the know IN to kill the switch, but if you pull it back out, all that happens is the sleeve/ knob slides out a short distance, but does not actuate the switch. I'll have to open the trunk to turn it on.
This will make a GREAT anti theft measure. No power, and you'd have to get into the trunk.
Something on this order with a sleeve sliding over a rod. A simple collar on the sleeve near the outer wall will keep it coming clear out
fetch
I ended up doing this for now, I have no plans for drag racing , But in case I do decide to, Its already in the back!
