Loosing a few electrical things intermittently
MikeyM
2:25 PM
NorCal
Hi all,
I recently changed my wiper motor switch from an incorrect 2 speed to 3 speed switch. I removed the instrument (Rallye) cluster to do so and after reinstalling, all seemed well. However, a couple times over the last week I have lost turn signals, fuel, oil, and temp gauges and then they return after I restart. If i recall correctly, there was some "main" wire that fed all of these but I can't recall which one it was. I was going over the FSM wiring diagram and it looks like multiple wires feed off of the fuse block so perhaps I jostled / loosened something during my switch replacement. Any ideas? I have checked all fuses and I will get up under the dash to make sure all connections are seated properly.
Thanks very much,
Mikey
Check ignition switch and connections to the switch.
Sounds like the issue is on the accessory keyed on side. power from switch should provide power to the key-on side of the fuse block.
