383MovingViolation
Sounds to me like the starter is still running when you let the key up off the start mode. I would check the start circuit and also take the starter out and check it on the bench.
			That was one of my first thoughts too. I got under the car and looked through the inspection cover. I literally watched the solenoid engage the gear spin the motor over, then retract back. All worked exactly as it should. Can't be the starter.
Well i set a personal best Solo Transmission removal of 1 hour 45 minutes. Pulled the torque converter off and was upset that there seems to be nothing wrong. Both spline shafts seem to be well lubricated and in good shape. The torque converter itself doesn't seem too upset, it was totally full of fluid so that's a good sign.
Can I take off the plate behind the torque converter to have a look inside without any parts falling out?
I'll be honest, i was kind of hoping to see carnage in there, but nothing seems to be wrong. I'll post pictures tomorrow, we've got to figure this all out.
That sounds like the starter not disengaging. How did you check to check the starter
OK ... does the noise intensity change/follow the engine RPM? The video was only the engine at idle ... at least I think it's at idle.
If it's not the starter with the relay stuck in then where is it loudest, you say you took everything off put in the video I can see the fan spinning which means you have the water pump attached. With that much off already it is easy to take it off just to check, some sealant and gaskets is the only cost. check the pump blades.
Also like others rev it does it change with the rpm's? if it does than it is something attached to the motor or internal.
I assume you have a yoke stuck in to hold trans fluid right???
