Wietse
Hey all,
I am setting up a lubricants list to use on my '69 Coronet.
I would like to change rear axle oil, power steering oil and brake oil for a start as i am not aware of their last replacement and just want to make sure all is fresh oil.
ATF oil replacement is kinda hard as you can only replace it partially by draining the sump, but at least i will need some good oil for a top up or start flushing the transmission with new oil.
Mind you, I am in Europe and don't have the luxury of selecting all the Mopar and or other types of preferred lubricants you guys are using over there, i ended up with Kroon Oil.
Kroon Oil is a good manufacturer of lubricants and they actually have a Classic line of lubricants for older cars.
As per their recommendations through their website:
Auto tranny: Kroon ATF Dexron II-D
Power steering: Kroon Classic ATF-A
Rear axle: Kroon Classic Gear LS 90 (Sure Grip models) (MP 90 for others)
Brake system: Kroon Drauliquid DOT 3
Could you guys agree with a list like this?
I don't really have any arguments against the oils, just something you guys might know from experience.
Regarding the auto trans oil, they have other oils as well but do not show up in their recommended list for this car.
The 3 other types of ATF oil they have are Dexron VI, ATF-A and ATF-F.
I have seen so many brands and types flying by here on the forum so i kinda lost it.
Guess it's best to stick to a good brand and use this.
Any recommendations?
