old guys rule
I need custom shift rods made for my 833 od. No idea where to look. Any Ideas?
Why do they have to be custom?I need custom shift rods made for my 833 od. No idea where to look. Any Ideas?
When I first dropped the engine and transmission in I discovered the transmission was not built for an a or b body asI thought. The shifter mounts were in the wrong spot so I got creative with a torch and tin snips to expedite the project ( dumb I know) later on I discovered that the rods needed creative adjustment due to cross frame interference. Got the torch out for adjustments and made them work however shifting is less than acceptable. It is an a body OD unit in a b body. Don't know where to take it to resolve the problem. Any suggestions?Why do they have to be custom?
Any suggestions?
I will take some pictures soon thanks.
Having a gander at what you have done so far will go a long way to help solve your problems.
Make em yourself…. I did ….I need custom shift rods made for my 833 od. No idea where to look. Any Ideas?
I will give that a look. Thanks, DaveMake em yourself…. I did ….
3/8 tubing, spherical rod ends ……
Welderruuupppp …
