Something has been bugging me, so I'm going to put it out there.
When I look at 440 RB, at least from 66-71, I see it as superior to the chevy BB - like a 454 - from the same timeframe. Ok, granted the stock Mopar heads, compared to a 454 Chevy BB, were slightly smaller (less flow), but a lot of everything else can be argued as better. Many of the stock 440 features are now desired aftermarket Chevy BB upgrades... such as large bore lifters and shaft rockers. Also, Chevy BB valve train geometry leaves a bit to be desired and to stabilize it you have to put in oversized rocker studs and a girdle, or - ironically - shaft rockers. The structure of the 440 intake manifold is better... such as no water and you don't have to remove the distributor to pull it. The distributor location and the use of the halfshaft in the 440 is just smarter. The 440's external oil pump, which can be adjusted, is smart. Granted, 454 does not have exhaust neighboring ports, which is helpful.
The aftermarket has really focused on chevy for obvious reasons, but that doesn't necessarily mean it was a better block.
Anyway, let the knives fly.
