steve from staten island
- 2:53 PM
- Sep 24, 2012
- staten island,ny
So i dropped the tank and removed the useless aftermarket sending unit. I will tell you i destroyed it in trying to get the gauge to work. I then took it apart and now i know why there not reliable, there made like the cheap imported **** that they are. Its garbage inside. I only hope a OE is made better.
I ran jumper wires from the sending unit to inside my car and worked the sending unit while i watched the fuel gauge. To things i found were the gauge is slow to react and it takes a lot of movement on the sending unit arm to get a reading on the gauge.
If we look at the total moment of the arm, say from empty to full, id think 50% would be half a tank on the gauge.
I put about five gallons in the tank which i had up on some blocks of wood. To get the tank to read quarter full i had to bend the arm in such a way that now the swing of the arm was less. What i mean is with the float resting against the tube as in a empty position the arm was not at the bottom of its throw its now about 30%. The gauge reads were i think it should with 5 gallons but i doubt its working correctly. I would have to see when i start to fill the tank up at what point does the gauge read full
I ordered another aftermarket sending unit which I'm hoping will work better
This really has me stumped. When i ground out the sending unit wire the gauge pegs all the way. But is the problem in the gauge? All the wiring is new and the grounds are good
Any thoughts are appreciated
