67coronetman
Ok guys here is what i have my 440 went down a few months back due to a roller lifter failing.. So i pulled it all a part cleaned it and of course used all new parts where needed i did not have the money for a roller cam & lifters so i used a mopar 312/590 cam and lifters with the correct springs on the heads. I put the motor back just like i had it from before except for the roller cam & lifters i got it started but it runs rough it misses at idel & when you bring up the RPM It misses & the motor shakes not violent but more than it should and when its running and you stand behind the car it should have a crisp cam sound or flow coming out is how i put it. Its very funky sounding not a sweet rumble sound like you would think...
Here are a few things i have checked so far...
1. Plugs & wires & cap & rotor
2. Cleaned and check the carb very good seems to be operating correct.
3. Checked for Vacuum leaks & found None.
4. Fuel filter is clean & free.
5. I have not found any wires touching or shorting out any where.
Things i am going to do still and any help would be very appreciated.
6. Do a compression test.
7. Recheck my timing & Distributor placement.
I am very frustrated at this point & need some advise & help thanks again.
