Moving on from my7 blade fan to no thermostat??
pedal2themetal
7:40 PM
Idaho
HI,
Well running without a thermostat cause it to run hot especially in traffic? Its not boiling over now but getting purity hot
I ran mine briefly without a thermostat when I was getting the rust out of the block.
It ran pretty cold maybe 150? but I didn't drive it in traffic.
Is your radiator any good?
If everything else is up to snuff, 150* is about it. You’ve got problems somewhere else.
I had a never ending overheating problem until I looked up the PN on the fan and found it only had an inch of pitch and was for a slant-6. It had 7 blades which it turns out means little to nothing about how good the fan works.
I changed to a 2-1/2" pitch fan and now it will blow a hat off your head and runs right around the thermostat temp (185) after it's warmed up.
It's worth looking into. More pitch is more better.
The flat /6 fan was a 200, the one I use now is a 215 or 216. The parts book lists the pitch on the factory fans so you get the best one.
