Aron Gleason
Looking for some pictures of plug wire installation on 440 msd Distributor cap. I would like pictures that shows where number 1 wire is. Thanks.
Number 1 can be wherever you want it to be. But generally it is around the 4 o’clock position.Looking for some pictures of plug wire installation on 440 msd Distributor cap. I would like pictures that shows where number 1 wire is. Thanks.
Yep, in a CCW order. Where #1 is, is wherever you make it.1-8-4-3-6-5-7-2?
Your right it can be wherever you want, but I always locate it per the Service Manual. The way I look at it, it's around the 7 o'clock position.Yep, in a CCW order. Where #1 is, is wherever you make it.
Yeah Unfortunately. Just wondering if I were to run a plug wire on top of the msd cap if I could use the top piece to hold them in place?That isn't real easy, to many wires have to cross the cap.
Thank you. I appreciate that. How do you like that distributor?
After looking at @OSDart 's picture I retract the above statement 4-5 o'clock position is correct. Also his routing looks great.Your right it can be wherever you want, but I always locate it per the Service Manual. The way I look at it, it's around the 7 o'clock position.
MSD is top quality. Took a little bit of trial and error getting the right spring/springs combination.Thank you. I appreciate that. How do you like that distributor?
