Moparjack 489
Yes, you right . Sorry I write only spacer not valve cover soacer for rocker clearance , my fault .Ok originally it sounded like you were using some type of distributor spacer not a Valve cover spacer for Rocker clearance.. Can you post a pic of where it is actually hitting?
I not have actual a picture right away from the clearance problem but , I will re -check the clearance problem and if it just the valve cover spacer itself like “ Big A, “ said , I will grind them and make a picture after I clear it .
