The coupe looks like the twin separated at birth! So it has R/T scoops and emblem and 500 trim on the sides. Cool! Are the scoops functional?View attachment 196991you are doing it the justice it deserves.
I have a near clone to yours. but a WI car!! LOL!
 A lot of the usual rot in the window channel.
 For those of you who have never taken out a back seat, it's unique.  The rear cushion lifts up off of metal brackets.  The bottom cushion is held on by two latches on the front edge of the seat frame, one on each side of the hump.  You take the heel of your hands and push down hard on the leading edge of the seat and it pops 'em out.  Don't push down towards the middle of the cushion - how do I know?  Because I did it at first and punched a hole in the vinyl.:nono:
Thanks 451. I like it too, different from most of the cars you see at shows. Even as I say that it's probably not staying that way.Nice car, I like the T7 Bonze with tan interior.
What color are you thinking of going with?Thanks 451. I like it too, different from most of the cars you see at shows. Even as I say that it's probably not staying that way.
I agree, and the rear window sealing isn't much better. After sandblasting there was swiss cheese in both the front and rear window channels. Some of the holes got patch panels and the smaller holes were filled with All-Metal.I sure wish Ma Mopar would have done a better job on the B Body windshield gaskets!!!!! Everyone I've seen look that bad or worse and they can be a bitch to seal just remember that when your reinstalling it and put plenty of butyl in there. Car looks great other than that, very nice starting point.
Great question 451 because I'm undecided at this time, but narrowing it down. Two colors I know it won't be are black or red. Reading through H2E's Charger resto I got hooked on the Dupont Copper Sunset. http://www.forbbodiesonly.com/moparforum/showthread.php?45279-1969-Charger-R-T-resurrection/page16
And then there's Dupont Harvest Flame:
http://www.moparmusclemagazine.com/...mopp_1108_1970_plymouth_gtx_exclusive_photos/
Since then I've noticed killer copper tones on Dodge Ram, Toyota Tundra, even Kia. And then I saw Mechanic's thread of his T5 Coronet and it looks awesome.
On the other side of the color wheel I really like some of the silver tones out there. The silver looks really good against the black vinyl top. In other words, I don't know what color yet. :icon_eyes: But choosing the right color is half the fun.
The interior is set though - it's going from saddle tan to black. The dash pad was cracked anyway and the rear of the dash was rust infested and I had it sandblasted, so a color change wasn't a big deal. I'll post some pictures later.
And it sounds like you have more work cut out for you than I do. So far no major rot has turned up.
Looks like you've got a great start on a solid project. That will be one very nice car when done! I like it!
And the same to you. I've been following your thread - awesome build.
Nice work so far, and it sounds like you have come up with a plan. My Coronet was in much worse shape than yours and I had never done anything like this before, so if I can do it anyone can. It's easy to get overwhelmed but remember it's just one piece at a time.
Thanks BB. The Big Boys on this site, the ones who have done this before and have created masterpieces, they give me the inspiration. And it's members like you who haven't done this before and made it to the end that give me the confidence that maybe, just maybe, I can pull this off. One small step at a time...
 Hard to see, but there's masking tape with numbers taped to each connector
    Hard to see, but there's masking tape with numbers taped to each connector Also hard to see, but I have containers for each main component: Front fenders/grille; Interior/dash; Engine/tranny; Chassis; etc.  Each container is stuffed with labelled baggies with nuts, bolts, screws, etc., etc.
  Also hard to see, but I have containers for each main component: Front fenders/grille; Interior/dash; Engine/tranny; Chassis; etc.  Each container is stuffed with labelled baggies with nuts, bolts, screws, etc., etc.  There's probably a better way to keep track of everything, but this is what I came up with.
 There's a snail trail of rust where the dash pad ended.
Thanks Ron. I mentioned before that I've taken hundreds of photos and written pages of notes, not sure if I'm giving too much info in these postings. I appreciate the kind words.
Thanks for the encouragement Prop. I was surprised how clean it was underneath the cowl. The air plenums had their share of leaves and debris collected inside but they will restore nicely.All the info/pictures you're posting here i'm sure will be helping someone else down the road. Thanks for taking the time to do so. Nice job on the cowl removal. A lot of the times the air plenums are rotted apart (thus water leaks right into the car), but yours is pretty dang nice. Good news is those are pretty ease to get aligned back on there straight, because of all the different angles that need to match up. Kind of align themselves.
