Last Sunday, the wife and I took a road-trip to PA to pickup a heater box and a few other parts from QuickBpBp (Brett). Thank you. Brett! I took it apart and, of course, it was full of rodent nests. Did I mention I HATE rodents!! I removed all the nests, acorns and feces with my shop vac and then gave it a good wash. As with almost all 50+ year old heater boxes, some repairs were necessary. The area beneath the blower motor was pushed in slightly and the two round protrusions were chewed up a bit by said rodents. Also, one of the raised areas surrounding one of the mounting bolts was damaged/missing. The area between where the heater core pipes poke through was also broken out. Just about every heater box for sale I’ve seen has this area missing, as well. A little epoxy, pieces from my original trashed heater box and some patience, I was able to get the box looking a bit better, I think.
Road-trip! (It only took a little over 5 hours each way)
New heater box:
And few other parts:
Rodents!!!!
This area was bent in and the cylinder sticking out was chewed a bit:
The base to the long mounting screws was broken off and a large crack. You can see the second cylinder sticking out with rodent damage in the foreground:
Heater core pipe mount. This area is almost always broken. I made a template and cut out a piece from my original heater box to patch it:
This corner was bent down and cracked:
More to follow:
New heater box:
Rodents!!!!
More to follow:
