My new to me 64 Polara
Are you selling some of them?? I need a water temp sensor for my 64 Polara. The one I bought has resistance readings from 675 cold to 90 hot. I understand the correct readings should be around 90 to 10.
No to selling but I can git you the numbers and you can look on E bay for a good one.
Correct Ohm reading on a 68/70F shop temperature sender should be about 360 ohms. Once the engine heats up the gauge will read correctly as it goes through it's 72 or so ohm "cold" (gauge just starting to move) to 10 ohm full "hot" on the gauge.
Yes. That is what I read on my 69 Roadrunner, but 675-90 on my 64. Same sender just too high of a resistance reading.
Temp Sensor for the 64 is a Filko #2030. I don't see one for sale on E bay right now but keep looking. Standard Ignition is usually good as is Borg Warner.
I just picked up a new dimmer switch for $20. May be next week I can get my multimeter out and do a resistance check of my sender just for fin. I need to test out my turn signal switch as well.
Thanks
Look at these beauties. More to come.
I'll just post these here. I had some Pay Pal money to use up. :thumbsup: :lol:
Merry Christmas to me. These are right hand threaded ones. Now to find some left handers.
My last ordered tie rod sleeve is out for delivery today. I freaked out yesterday, I remembered ordering a lower ball joint and another upper and I searched all over this place and couldn't find them. Come to find out they hadn't been sent yet. :BangHead: :BangHead: :BangHead: :lol:
It has been about a month since I ordered them so I asked on E bay and got a computer generated message that said I should contact them after Nov-28 which was the "should receive by" date. I see this morning that the seller has packaged them for shipping and I have a tracking number at least. Apparently you can get results if you light a fire under someone's butt. LMAO
Ain't she pretty?
