Looking for some advice from any of you brake experts. I bought a hardware kit for my Dana 60 rear 11x2.5" rear drums. 3 questions: 1st - Does the parking brake cable ball end just sit in the slot, or is there supposed to be some kind of clip holding it secure? 2nd - The kit came with the green lower spring that I am holding. The silver one I installed was on the car when I tore it apart. I called and questioned this and was told the thicker silver spring was for 10.5 in brakes. I don't see a decent way to use this green spring, so which one would be correct? And 3rd - Do I need to buy and install the auto adjuster kit, or will it be ok the way I have it setup and I will just manually adjust the star wheel every so often? The silver spring is putting enough pressure on the star wheel to keep it from moving on its own, but if I use the green spring it wont.
