- 3:01 AM
- Apr 13, 2012
- Granite Bay CA
I know this sounds weird to start off with but it is true and may be relevant.
I admit that while I am pretty handy with many aspects of these cars, electrical stuff is still my weak point.
Four cars:
1970 Charger
1967 Dodge Dart
1972 Plymouth Duster
1975 Power Wagon.
All of them have working headlights, taillights, turn signals and hazard flashers.
I have not checked the fuses to all of them, it just now occurred to me as I'm writing this.
I did do a forum search and while there was some helpful tips, I wonder if my situations could be a bit different.
The instrument panel in the Charger had functioning lights when the panel was in my other car. The fuse panel was changed to one with 7 fuses. The panel dimmer was not moved over from the other car, it was in the instrument panel that came in the car.
The original cluster is the one in the middle. The car sat for 24 years before I got it so I don't know if the dimmer is crap.
The other cars....the 67 Dart, 72 Duster, 75 Power Wagon all have had different instrument panels swapped in, I rarely drive them at night so the lack of lighting has not been an issue but I would like to get them working.
The Dart had dead gas and temp gauges. I replaced a sending unit and the voltage limiter and they work right now.
One response to a thread on this had a guy that went through 4 headlight switches before he had one that gave dash lights. All 4 gave headlights and parking lights.
This has me wondering if all 4 vehicles have the same cause for this issue.
I'd appreciate any suggestions on where else to look to fix the cars. The A bodies seem to use the same type of switch for many years, I have 10 or more spares to try. I'm not sure of the unit used in the pickups. I know that the Charger panel dimmer is unique to these cars. If the Charger dimmer is bad, is there a way to bypass it's function to where it gives dash lights but is unable to be dimmed?
Thanks for any help that you can give.
Four cars:
1970 Charger
1967 Dodge Dart
1975 Power Wagon.
