No lights, ignition, nothing.
72_roadrunner
1:39 PM
California
Just finished the interior on my Satellite yesterday and to celebrate I got a new Pioneer stereo installed at a local stereo shop. A little later that day after I got home I noticed the stereo started to blink on & off and now nothing works :( No lights, ignition, nothing works now :( I checked the fusebox and bulkhead for any loose wires or melted terminals but didn't find anything. Any help you guys have is appreciated. Thanks.
Radio installers may have reconnected the battery but did not tighten it up???
Check power at the starter relay--which feeds the inside of the car,and also feeds the fusible link as well.
Thanks Wagun. I'll check out the starter relay I think your right I just really hope the fusible link isn't fried :( I hate dealing with anything electrical that was the main reason why I let a shop install the Pioneer. Installers didn't disconnect the battery and I already checked my battery connections too. I just hope it will be easy fix and not a freakin headache.
Got most things working again :) loose connections at bulkhead & at ammeter gauge. Now the only thing not working is ignition I can get it to crank over at the starter relay switch but won't start?
check the neutral safety switch wire and its on the far left corner of the relay on the bottom connect it to ground, if it starts its a bad neutral safety switch
Got it fixed I found 1 more bad connection from the steering wheel coupler connector. Also cleaned the bulkhead connector with a wire brush & contact cleaner and then packed all 3 connectors with lots of die-electric grease :icon_thumright: Electrical problems are gone :D
