No Power To Side Marker
Richin65
3:23 AM
Idaho
This one has me scratching my head. All four side markers on my 68 Charger worked fine until recently. I noticed my front passenger side marker was out. I checked the bulb, it looked fine, but replaced it anyway. Still nothing. I took a meter and tested the wire to the light and I have no power. Any thoughts? Everything else is working fine. Thanks!!
Is there a 6 wire connector next to the battery in the lighting harness? That's the next spot to check. Follow the wire. There's no 68 Dodge FSM on MyMopar.com, so I can't look at the diagram.
No power to that wire at the 6 prong plug (near the battery tray) for the front lights. I would think if the switch was bad, the other three side markers wouldn't come on. Possibly something between switch and bulkhead under the dash??
As I've come to learn, if you have no power it's probably a ground issue.
