440SportSatellite
So I finally got my gauge cluster back from Auto Instruments a couple of weeks ago, and just got it installed this weekend. After getting everything back together and starting it up, everything seems to work fine, including the tach I had them install, which I wired up. The only problem is the oil light is coming on... I'm pretty sure it's a wiring issue, as when I disconnect the wire from the oil pressure switch behind the manifold and ground it out with the ignition on the light comes on as well. I tried to be careful and get all of the connections nice and tight on the circle connector at the back of the cluster... So I guess the question is, is it possible that it's an issue with the cluster itself and I'm going to need to send it back? Or is it more likely something I messed up when putting it in? The wiring harness in the car was replaced by a local shop when the 440 was dropped in, before I bought the car. I'm not really enthused about pulling the dash back apart to check all the connections behind the cluster, but I guess that's the next step. Any insight anyone here might have would be greatly appreciated.
Thanks!
Thanks!
