Oil pressure sender
back of engine,at firewall.almost right in the middle.
Thanks for the reply....There are two plugs back there, is it supposed to go on the driver side, or on the passenger side....
I'd be lost without you guys......Thanks again
There are usually two holes, one may be a 1/4" pipe and the other is an 1/8" pipe. It goes in the 1/8" pipe hole and I think that faces the drivers side. It really doesn't matter from a pressure reading perspective since it's the same oil galley, so just make sure the wire reaches wherever it ends up.
Direction
Factory, it leans toward the driver's side of the car - so that standing on the driver's side you can see the terminal on top. Not that it makes much difference as Meep said.
Thanks for the replys guys......Yes mine had a 1/8" npt on the left side, and 1/4" npt on the right. the sender went in as pictured above.
