Oil Pump Choice
dryheat
7:24 PM
Glendale, AZ 85308
I am presently acquiring various parts for my 383 Polara. This is going to be a bone stock 383 back road/boulevard crusier.
With respect to the oil pump there are 3 to choose from ... standard volume ... high volume ... high pressure. I'm leaning towards the standard volume (of course), however, before I pull the trigger I was hoping to get some opinions/explanations as to whether the high volume or high pressure would provide any added benefits or is it just a waste of money.
Thanks ...
use standard volume. a high volume is only needed for engines with loose clearances and high oil demand, basically bleeders. a high volume is of no use unless the stock 3/8' pick-up is enlarged to 1/2" and capacity increased. a stock engine will live nicely on a stock pump. pressure can always be varied by changing the relief spring or adding an adjustment to the relief spring cap.
Thanks ... that was exactly what I was hoping to read.
AND it makes a lot of sense too!
Thanks again ...
Lew nailed it. I personally like to err on the high side when it comes to oil pressure. The 70 lb spring as supplied in the Melling HP (std volume) pump is good.
