wedgeheaded
I did a cam swap in my 75 360. I have #1 at TDC. What direction should the slot in my oil pump drive be pointing to make sure I have room for my vac advance pod and dist adjustment? Also, is there a trick to getting the hex end into the slot while rolling the helical gear into place? Thanks in advance
