HS 69 Charger
Now that I have my Dash all restored and calibrated I am going through the sensors to validate each plus the wiring. I have the Temp sensor all squared away plus its wiring resistance checked. Now am on the Oil Sensor. Wiring and ground are testing good but sensor is a bit erratic.
Current one reads infinite (open) at no pressure.
Kicks in about 10psi at 30ohms
Peaks at about 15ohms at 80 psi but actually a bit earlier at 70psi.
Since the gauge is marked at 0 to 80 and calibrated at 70ohms = 0 and 10ohms = 80 that is what I expected from the sensor. Or at least reasonably close.
I got a new one from Napa. It reads infinite (open) all the time so that became useless as a second test. I will go back tomorrow to get another one but while I'm waiting, I would like to confirm what should I see on these sensors.
I saw another post that said 9 to 72ohms which is the range I was expecting. Just looking for confirmation of my expectation as i get another unit from Napa.
Thanks for any help,
Martin
69 Charger 383 SE
Martin
69 Charger 383 SE
