YY1
Does the motor currently run? 66,000 is what I would consider low miles, and still good for another 40K or so.
You could save a lot by simply running it without rebuilding.
4.88 gears is a real good way to drain your wallet real fast as well. So is dual quads.
If it were me, I'd consider a modern, split profile cam, one step below the 284/484, and see how it ran.
You'd probably be in the 275+ NET HP range with all sorts of torque and be pump gas friendly.
I'd also stick with a 3.55 rear and a low stall converter 2K or maybe even stock.
66/67 non-Charger B bodies are pretty light.
You might be surprised how well it does.
