Porta power to get header iff the torsion bar?
koosh
3:05 PM
CT
On a 68 Charger, the header inner primary tube on both sides press up against the torsion bars…. If i had a porta-power or small hydraulic jack, can i bend those tubes away from the torsion bars, using the torsion bars to push against ?
Or would it wreck the bars?
I figured the tubes are hollow and bars solid steel…..
Best to mark the tube, pull the headers, and bend the header tubes on a bench. The jack will almost certainly mess up the torsion bar. Depending on how bad they're rubbing, my first try (to avoid removing the headers) would be to heat up the tube and hit with a hammer.
I wouldn't hesitate to jack the header over, make sure all the bolts are tight up top.......it'll move
