Post your 10 second combo's
started reading these again. Did not remember responding. The sponge in my head is full of useless stuff. Getting old and reactions are getting slower, been around since 52.Got to transport wife to doc's so I will but in a few additional bits and sign off. What I would like is where on this site should I go to ask some performance questions? want to change some ignition and fuel items ( make it more "streeteble").
Finally posting in the 10-second thread!
new 470 combo is running well. Combo: Full weight ‘67 Satellite, 3775 in the beams. The mill is a 400 based “470 combo” that actually works out to 468”. Block is decked .020, so I held the stroke to 3.875 to land the piston at zero-deck. Offset ground factory RB crank; 6.70” BBC rod & 1.322 ht Icon pistons works out to 11.3:1 with TrickFlow 270 heads & a .040 Cometic gasket. Bottom is studded and utilizes a 440-source girdle assembly. Intake is a Holley competition HP series 1000cfm annular booster 4150 on a home port-matched Indy intake. Cam is a Howards Custom-grind solid roller, 263/269 @ .050 & .683/.688 lift with 1.6 rockers. Hooker Comp 1-7/8” / 3” Headers. A simple MSD 6AL2 & Mallory dizzy light the mix.
trans is a basic 727 with a cheetah forward LBA valve body and a Dynamic 9-1/2” converter. Out back it’s a Dana60 with a 35-spline spool and 4.56’s turning M/T 29.5x10.5 PBR’s on 10” rims. Suspension is all Calvert stuff; shocks, springs, and bars.
best pass 1st time out on the new motor: 10.55 @ 127 w/ 1.480 60-ft.
Hello all. I get to update my last post.
New best and still chipping away at it.
Hope I can come up with a light like that when it really counts, this was just TnT.
I believe I have fuel delivery issues
Update after a 2nd year on the “new” mill: ran a best of 10.42 @ 128 this year.
It’s been on the converter that was custom built for the old much milder 451. It’s a Lupo/Dynamic 9-1/2” unit, and it’ll be going back Dynamic to be tailored more to the new motor as part of this off season’s project. Additionally, I have a brake valvebody ordered from John Cope.
Might be a little faster with the right ‘vert; but certainly should take a big step toward being a better bracket car.
Very impressive for the combo you have, you did a good job in building the car and motor.
Gary you are really flying now. What does the converter stall to behind the current combo?
Not slow
'73 440 - .030 over, '65 stock steel crank 445.8 CI
11:1 Arias flat tops, fully prepped LY rods
Out of the box Indy EZ heads, Super Victor, 1050 Dominator
Custom Robert Landy solid flat tappet,
roughly .600 lift with 1.6 Crane Gold rockers
CPPA 2-inch primaries w/extensions
727 w/transbrake and 4800 ATI converter
30x9R Hoosiers, Caltracs w/mono leafs Caltrac shocks
8 3/4, spool 4.56 ratio, race weight - 3650 lbs
Best to date - 10.58 @ 125 / 1.45 60ft @ 2100 ft
Shooting for 60 fts in the 1.30's
Need a Dana for this car
67 Super Stock style Coronets make such good looking race cars. Really like this one.
I’ve had the 2-step set as high as 3k, and it flashes to about 4000, maybe a little more. I’m guessing that this combo would really like the flash up around 4800 - 5000. We’ll see what Dynamic wants to do with it.
Congrats :thumbsup::thumbsup:
First time with a 10 N/A in this car.
440 .055 over
Victor MW cncs
270@ 50 ish solid roller
Indy 4500 intake
1050 prosystems dominator
5500 ish ATI
Big TTIs
Was in the 11.30s @124 with 30.5" tires and a 3500 converter. Swapped to the 5500 and 28s. First decent run nailed a 10.53 @125.8. The trans had issues with delayed shifting so that was on the 7000 chip every shift. Bumped up to 7200, and while the trans got worse, pulled 127, still on the chip at the top. 1.47 60'. So there's more in it with a trans and some tweaking. Never touched the carb, or timing(32°).
All steel 67, stock driveshaft, small joints, 8 3/4 4.56 shitty S/S springs. Calvert front shocks and some old rear truck shocks. Lots to do drivtrain and suspension wise. But hey! It was a hell of a Lotta fun!
Finally in the 10s.
Runs 11.6 N/A.
10.75 on 150hp nos.
Breaking up at the top end tho.
Think it should have more mph.
440cui
Cast crank, ly rods, L2355 pistons
Cleaned up 75cc e street heads.
10.6 comp
Hedman 1.3/4 headers
Solid flat tappet cam 250 dur .588 lift
Perf rpm manifold
Qf 850 dp carb
Msd 6al
727 reverse valve body
9.5" tq ca 4000 stall
D60 power lok 4.10 gears
90/10 front shocks, rear adjustable
Ss springs
Mini tubbed
28x4.5 front runners
28x10.5 stiff wall rear
Stock body, stock interior.
Weights 3810lbs with driver and full tank of fuel.
Hmmmm....10 second combo, how fast I can woof down a cheeseburger or how fast I need to get to the bathroom before I piss myself, hows that for a 10 second combo:wetting:
Nice one Kjalltrac!
Great looking car and stock looking under the hood.
You just need a decent steel crank and trick rods then you can go 10's on the motor!
Better intake and a dominator that got us down to 10.40 N/A.
But next time out we are going 512ci and hoping for a N/A Nine...:drinks:
