That’s funny because the cam that was spec out was for great midrange powerThe 1.90 sec 60ft and the 117 mph actually indicates that a bunch of time is bringing given up mid track.
I don’t mean the motor. I’m referring to the driving and shifting or somethingThat’s funny because the cam that was spec out was for great midrange power
Should be interestingI have a video, but have to wait for daughter to get off work to post it
Video is on post 262Should be interesting![]()
Sounds like you were in 4th way too soon?Video is on post 262
Could b right.Wasn’t watching the tach, just shifting by feelSounds like you were in 4th way too soon?
I went without a tach for a few years. I definitely had a problem with the valve springs. Right after the hard pull really started to roll in, it would fall off. Sure enough, I had the stock springs tested when I had the new ones installed (yes, I was that sure I needed them I bought them and then had the old ones tested out of curiosity and to weigh my "instinct"). Night and Day, literally an entirely new experience. What a RUSH.Wasn’t watching the tach, just shifting by feel
It was kinda hard to tell from the video, but I think the 2-3 shift might be worth. 100 alone.
I tried a shift light years ago and for me it was a disaster. Almost like going from an analog gage to a digital, I couldn’t get used to it.I went without a tach for a few years. I definitely had a problem with the valve springs. Right after the hard pull really started to roll in, it would fall off. Sure enough, I had the stock springs tested when I had the new ones installed (yes, I was that sure I needed them I bought them and then had the old ones tested out of curiosity and to weigh my "instinct"). Night and Day, literally an entirely new experience. What a RUSH.
Anyway, I got a nice Autometer tach with an external shift light. The tach fit perfectly recessed in the factory tach/clock location, and the shift light on the dash above it.
Now I have a stand-alone shift light that is triggered by my Dakota Digital RTX gauge system. The tach is awesome, but the shift light is something I rely on, and I think us 3 pedal guys benefit the most from a shift light, being as "busy" as we are on the track.
At first I only looked at my tach, once I got it, for information, to see how many RPMs I had been hearing and feeling equated to. I use it to check idle speed, but the shift light is my WOT go to for me to grab the next gear.I tried a shift light years ago and for me it was a disaster. Almost like going from an analog gage to a digital, I couldn’t get used to it.
To tell you the truth, I have gotten away from even watching the tach.
With the faceplate gears in the trans now, if I keep the gas down the shifts are almost instantaneous. I might try a shift light again.
Meep;I'm very impressed that you're running those numbers through that restrictive air cleaner. The combo I'm planning is very similar;your engine specs are close,3.91 gear with the new 9X29.5 slicks are in my plans. I was hoping to run mid-to-high 12's myself;looks like it's possible.
Im not sure this is the answer to your question (engine build should determine shift point).Hi - It's Scott. With 391 gears what rpm are you at when you shift? 1/4 mile right?
Mine had a 391 sure grip and I was told that it had run 12s in its prior life. It just seems like the ol 440 would be screaming at the end of 1/4 mile. I saved the 391 and recently installed 323.Im not sure this is the answer to your question (engine build should determine shift point).
But assuming he achieves mid/high twelves, and assuming a 727, with 3.91 gears and 29.5 tires, at 108 mph (typical for mid twelves 1/4) it should be slightly over 5000 in the lights, (5052 oby the calculator I use).
