Pro-pinions requested!
Hollis P. Wood
12:08 PM
Fernandina Beach, FL
Adding a trio of auxiliary guages.
For the water temp sensor location, I went with Meziere’s water neck spacer.
Question is: Leave it anodized black or paint it block blue?
I would leave it black. If someone actually looks at it, they will know that it isn't stock anyway.
Turquoise & change that neck unless your looking for trouble + throw in a new thermostat but make sure you test the thermostat prior to assembly just had issues with a new non opening thermostat
What would actually look better all around would be the housing that has 2 sender locations.
Appreciate it.
Ordered a new neck from Mancini.
New thermostat worked as advertised at 180 degrees. Also important to have an accurate thermometer.
