Project Superbee new engine breaks into the 10s
retro
12:59 PM
florida
This is a pump gas 440/493, roller hydraulic, Eddy Heads, 3:55 gears , 3600 stall. I drive this car to the local track, run all night and drive home. I am still tuning and the car needs some Caltracks and a 950 carb. Hope to get a few more tenths shaved off in the next month or so.
http://www.youtube.com/watch?v=vxU9aLwNWT0
Now that is a wonderful thing!
What cam is inside?
Port work on the Edelbrock heads?
that is one beautiful car you got there!
you did a great job on it.
i got a 69.5 superbee goes 11.97 with stock everything,its a pure stock motor. 11.0 compression.
i'd go with a 4.10 gear and a 4600 stall converter to wake that bad boy up.
looks great in blue with white bumble…..Which edelbrocks did you use? #60189, 84cc or 88cc and did you match the pistons? Love it man..
Vry nice Super Bee. Congrats on breaking in the 10's. I am building a 493 right now to replace the mild 440 in my 63 plymouth. I will be hoping for 10's myself. Ron
What cam is inside?
HUG HER4652BL
HYD ROLLER CAMSHAFT 108º LSA +3
HYDRAULIC ROLLER / THREE BOLT TIMING GEAR
$421.00
Hydraulic Roller / Three Bolt Timing Gear
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .592"
.576"
Intake Duration at .050"
Exhaust Duration at .050" 246°
252°
Lobe Separation Angle 109º
Intake Opening at .050"
Exhaust Opening at .050" 18° BTC
57° BBC
Intake Closing at .050"
Exhaust Closing at .050" 48° ABC
15° ATC
Min. Suggested Cylinder PSI
Sweet Spot RPM 2000 - 7000
I used the 1.6 rockers so the lift is .592.596 .246 .252
FULLY CNC'D EDELBROCK RPM HEADS 88 cc 10.8 compression
HEADS W/ 2.19' INT VALVES, VITON SEALS, CNC PORTING & MINIMUM MILL
All the block work and balancing of the stroker kit was done by Hughes and the pistons '' Diamond'' were part of the package and have sizable reliefs machined into them.
Your car already is running a stout number .... curious, what are your 60 foot times?
The strokers that run well on the street really need a decent suspension to get them to hook thru the 330'
I love that car! 11.97 is phenomenal for stock. Is it an auto and is the stall converter stock as well?
its a column auto. with stock converter. motor done by best machine in michigan.
Retro my best 60 ft is a 1.57 and I average in the low 1.60's. Its all stock suspension with SS springs. I am running the 30 x 9 radial slicks on the street and strip. I know alot of NHRA stockers run the 30 x 9 radial slick and some run in the 9's. So I hope it will still hook but if it gives me trouble I can think about Cal Tracks. Thanks for the kind words and good luck with that swet Bee ! Ron
It will hook good right now at decent tracks. Ron
Awesome car retro. Just doesn't get much better than that.
You did a great job!!!!!!! What was the reaction of the corvette guy?? Is he willing to sell the vette and spend his money on a mopar now?
The owner of the Vette is a close friend of mine. He ran his best time on the same evening.
I have to come clean and tell you I recently had a 2007 Z06 Corvette 10.62@132 and decided to keep only one toy so I kept the Bee and away the Vette went. The manual transmission are too costly to run in these IRS machines.
We are running almost exact times and many times it comes down to reaction times.
Congrats on the 10 sec pass!!! Your Bee looks Awesum!!!
Superstock, Bee looks great and runs strong, where did you run 11;97 with the Bee???
Paul
