adk-roadrunner
I ended up buying a set of PRW 1.6 steel roller rockers. I went ahead and got the rockers setup and shimmed so they are centered over the valve tips. I also kept the side clearance that the instructions called for of between 0.0015 and 0.0020. I used a .0015 feeler gauge to check this but was surprised how thin that feeler gauge is doesn't seem like a lot of clearance to me. Everything was nice and free and seemed good. I cleaned everything up, assembly lubed, installed pushrods and adjusted everything for zero lash + an extra half turn per instructions. I found this to be around 25 thousandths with my dial indicator which is right in the ball park for lifter preload that comp called for. I also primed the engine and made sure oil was getting to all rockers and everything seemed good. The thing I noticed which concerned me was when a lifter was at max lift on the cam that rocker would have no space between it and the shims anymore. I asked PRW about this and they said that this is normal and as long as the play is there when the rocker is on base circle it should be good. What do you guy's think? has anyone experienced this where there is no side clearance when the rocker is under full lift? I understand there are people who aren't going to agree with the brand of rocker I purchased and that's fine. I'm not starting a thread to have a brand debate just to get some info that might be useful towards what parts I'm using. Thanks
