TLCJ
:angry4: I have to first say, have anyone ever had the problem with your brake lights working or not fully working except when i press the pedel to stop but only the passenger side rear lite only comes on and drivers side does not, and all the other functions work signal, park, flasher, except that driver side does not come on, i have changed out the the harness going to the stop lights, and checked the power to both lights to the bulbs, the right side has a brown wire, and the left side has a green wire and no power there, the only thing i have not changed is the the brake lite switch at the under dash brake pedal, but checked the power at the pink wire it is good there, and checked the turn signal at the steering wheele and the ground at the trunk lash, if anybody knows where to track down the green wire without having to pull the entire dash harness, Any body have any solutions or thoughts.
