68GTXNH
so, im sure the skin vs full quarter conversation has been beaten to death. thats not what this post is. i was reading the "mopar b body restoration" book which im sure most of you also have and it brought up a great point that i never considered before, and i can't find ANYTHING online about doing it this way.
they say they like to remove as little of the original metal as possible. almost all of our cars need new quarters at somepoint. but theres no nice way to just patch the lower quarters and have it not be obvious when you look at it from inside the trunk.
so what they do, is get a patch panel or a skin, cut out the damage, trim down the skin or patch to fit and line it up and tack it in. just like most of us would do. but then they drill out all the spot welds and melt out the lead and pull off the whole quarter. then they can body work both sides completely. butt weld and grind smooth inside and out and for the detail oriented people, even simulate the dip primer line and spray in the sound deadening.
then they reinstall it like a replacement full quarter, but it doesn't need any fitting because it came off the car to begin with. i think its a great idea. maybe a lot of work, but not more work if you want to install a full quarter anyways. gives you a chance to clean and prime all the metal underneath. and saves you on ridiculous truck freight charges for full size quarters. i think this is the route im going with, especially because i have a nasty dent across the body lines on the drivers side just behind the door, where itll be impossible to get it perfect without a hammer on the back side. . what are everyone elses thoughts?
