question regarding marker reflectors on 69 Roadrunner
beep69beep
3:34 AM
Norwood, Ontario
My front fenders were replaced with fiberglass fenders a number of years ago. I decided not to cut holes for the marker lights at that time but have since changed my mind about that decision. Can someone give me the measurements as to where to cut the openings? I still have the original reflectors.
There should be indentations/recesses where they go. If there are no recesses then they won't fit flush when you mount them and that will look worse than none at all. Given that they're just "reflectors" not lights, I'd leave them off.
They are recessed in a little bit Hopefully you can see them in these photos. But if you are opk with doing fiber glass work then you can make the recessed portion. And have the marker light bezel fit flush.
thanks, not recessed so that's probably why we decided not to put them in at the time. Every time I see another Mopar I am drawn to the marker lights. Part of the overall appearance of these beauties.
