Radiator hoses for big block, your thoughts?
'67Satellite
12:45 AM
Southern California
I'll be swapping to the correct water pump (driver-side inlet) and 26" radiator soon, hopefully this weekend. And i'll obviously need to replace the upper and lower hoses. Yearone carries both, but I was wondering if anyone knew of a cheaper source, and had some experience with another brand. And I don't care about factory correct markings/date codes, just want this baby on the road! Motor is a 440 and water pump is a '69 cast iron piece, radiator is a '67.
Let me know what you guys think!
Yearone part number I've been thinking about using are BG339(upper), and BG340(lower).
Yeah,
YearOne has good stuff but cant you get that hose at NAPA?
YearOne does not make the hose, they buy from a supplier just as NAPA or anyother parts supplier.
Hey! YearOne is running a coupon special this month but it is still more costly than ROCKAUTO, NAPA or any other auto parts supplier.
Just my 2 cents in this Obama catastrophied economy.
Super-bee_ski (mark)
Well if what you got at Autozone fit well, then i'll probably just do that. I was just worried about getting a good fit, that's all. I'll shoot over there and pick some up, worst comes to worst i guess i can return them. Thanks.
NAPA part #s NBH7602 upper, NBH7342 Lower. Decent quality hoses. If they don't fit just right you should be able to return them no problem.
O'rileys was able to get the hoses for me but it took some trying. I should be able to get part #'s for you tonight if i remember. They fit perfect but it took 5 tries to get the correct ones they kept sending me the pass inlet ones. will try to look tonight.
