MT_Mopar
I have a new set of Moser Engineering rear Axle Bearings 9400M coming on the UPS truck. I've had a small leak on one side of my 8 3/4 rear axle for a while, so I decided to switch them both out with the green snap-ring style.
I have a new Eaton Tru-Trac that I installed with the thrust block in the diff, after my shop presses on the green bearings I will need to remove the thrust block correct? Can I just push it out? If I remember correctly I put it in with some grease prior to installing my oem axles. With the green bearings the axles will stick in the housing further?
Also, any tips on removing and installing the inner seals?
Thanks
Thanks
