Rear Brake line routing for 69RR
GearAddict
Tampa, FL
Does anyone have a pic of how the rear brake line routes where it transitions from the engine bay to the inside of the rocker panels?
I'm replacing mine and the routing of the current line doesn't look right...
Heres mine
Just to add to this thread.....does anyone have pics or description of the location of the factory sprung front to rear brake line clips. I have already located the following clips, just after clarification of the remaining clips in the kit. 69roadrunner manual drums.
Clips located already (from rear):
Outer side of rear frame rail kickup
Inner sill in front of leaf spring perch
2 clips close together before the pipe bend as it goes thru the front crossmember
Inner side of front frame rail before distribution block
I have 2 clips remaining. Is there one to go on the inner side of the rear frame rail kickup? Also is the another clip to go on the inner sill as currently a large part of the pipe is unsupported from front to rear.
Thanks
