Rear Glass RIBBON SEAL which mfgr?
Moparfiend
6:11 AM
HOT
Looks like a few mfgrs out there for the rear glass ribbon seal. Looks like 3M and other more Mopar specific?
Which is the one I want?
I always used the 3m ribbon, along with pinch weld primer for butyl......
The prime makes for a good glue to hold ribbon in place. Just make sure that if you buy in bulk that you don't cut it to short after installation. You will have a gap if you do I always do the install then let it set for a few hrs then cut to fit.
Butyl is tacky stuff, all right, especially after warming up in the sun. 3M makes the best products. Tacky even during winter in a cold shop at 30F ambient.
Thanks for the tips guys!
Dang that primer is expensive! I guess I should not have painted and cleared that channel….
Southwest rubber might have the ribbon and napa has the primer.
