Rear shoulder belts in a 1970 Charger
Some people have precision instruments to measure and fabricate unique parts.
Others like me use tape measures, torpedo levels and caveman logic.
Inside the trunk of this car…
The retractors will mount to the back side of the upper rear seat mounting panel. Since it is sloped back for seat comfort and since the retractors Rich and I are working with prefer to be mounted “close to vertical/plumb/upright”, I’m looking at ways to make mounts to reverse the rearward angle of the seat back panel. The goal is to make a platform that is plumb to attach the retractors.
This bracket illustrates the concept…
When viewed at approximately the angle of the seat back panel…
Suddenly there is a vertical mounting point. Inside the trunk looking forward….
Look close, to the upper left you can see the horizontal slit where the belt passes through.
Note the diagonal brace and where it ends near the package tray. Now the right side.
To the upper right is the seat belt slot but look where the diagonal brace ends. THAT is Chrysler build quality in the 60s!
How much of this mis alignment is due to the drive shaft tunnel offset that our cars have? I never noticed this in these cars before.
The strange placement of the upper ends of the diagonal bracing means that the left and right brackets will have to be different. Those braces are important, they provide torsional resistance to the roof moving sideways in relation to the lower section of the car. Up front, the windshield in a small way achieves a similar function. I'm wondering if I could trim back the left side a bit like so:
I could add more welds to the brace to equal the right side...I count 7 spot welds there. If I cut and removed what is above the line, I could add welds below it.
I took a torpedo level (approx 10" long) and held it plumb with the top of it resting on the back side of the trunk/seat back panel. The bottom of the level was approximately 1 1/4" from the panel so I made a quickie cardboard mock up test bracket...
This will be attached to the trunk divider panel back side, likely welded at the side flanges.
The side flanges could be drilled and bolts with nylocks could also be used. I wouldn't want this to rattle loose not only for the safety issue but for the rattles as well.
Knowing I'd need to cut it to fit around the diagonal bracing, I got back into the trunk armed with scissors.
Right side, I'll trim the cardboard back a bit and test fit....
It is very hard to lay in a trunk, hold a flimsy piece of cardboard and get a decent picture with one hand...!
Look at the white cardboard piece. Note the distance the top is from the horizontal slot in the package tray where the belt passes through...
The seat belt sits real close to the edge of the retractor frame so maybe the brackets I'm making need more of a standoff from the trunk divider panel to get the belt in better alignment with the horizontal slot.
I might try to crawl into my trunk but the subwoofer is in the way. I just used the flat bracket mine came with and welded several spots to the diagonal brace where it touched.
The sloppy placement of the diagonal braces got me thinking. Were other cars as bad?
My red Charger, formally GREEN!
Those look pretty even. Next up, 67 Dart.
Okay, not bad. The Dart did not have slots for shoulder belts though. Now a 72 Duster.
The Duster had shoulder belt slots and the braces were pretty close to even. Finally, a 69 Dart:
The Dart had slots for shoulder belts.
The bracing looks even.
The Jigsaw Charger looks like the braces were installed by a first day apprentice.
Just weld in a full cage and install 4 sets of SCHROTH harnesses. :)
