My 4 speed shifter is pretty sloppy, I think I need a rebuild. I seen a kit for sale on ebay. Has anybody rebuilt their own? Is it difficult? Or does someone know of somewhere I can send it. and as always , thanks
I took mine apart, cleaned and regressed everything, readjusted the rods and it shifts perfectly. My shims looked fine so clean and lube is all it took
Its been a while but I put in new shims and had it apart a few times before I was Happy and drilled a hole for a grease fitting and used Lucas red and tacky.... as mentioned above exactly the way it came apart ... take photos use wire and tags to label it 12245 etc
I did mine a few years back, it's pretty easy. At the time I found a YouTube vid from hurst on how to do it but it wasn't really needed, just keep things in order.
Depends where the slop is. If you have the iso-clamp handle (factory MoPar) then you can get the isolation kit from the usual suspects. If you have the aftermarket bolt on handle then your slop is limited to the clearance between the gates and the pivot pin. I took my original iso-clamp shifter and made bushings for the pivot pin, but I have that capability so it was easy for me. Another thing you want to do is make sure all the pivot points are tight. Check all shift rods from the box to the plates on the tranny.
