MCODECUDA
I had my flywheel resurfaced and now my clutch pedal sets higher than my brake pedal. How can I correct this. @Dan Brewer
Correction: You will lose play as disk wears, but will gain play when surfacing flywheel. I would think this would be minimal unless it needed a lot of material removed.As the disk wears, or, in your case surfacing your flywheel, you will lose pedal free play. This can be adjusted on the rod connected to your z-bar. If you have everything correct, when fully engaged, pedal should come up high enough that the over center spring will take the pedal up to the pedal stop, thus pulling your throwout bearing back slightly from the fingers on your pressure plate.
