Rocker studs
Rob Vaughn
7:13 PM
What is the tourque for the rocker shaft studs on the trick flow 240 heads? 55 or half that since they're aluminum? Harland sharp assembly.
Thanks Rob
What does TF recommend? IIRC Edelbrock says 45 on theirs.....
I cant find anything in trick flows specs on that. I'll check harland Sharp
Does edelbrock recomend blue loctite?
Don't recall but green might be a better choice....
Hmmm, I think the stud just goes in hand tight and the nut gets torqued.
I know head studs are done that way....you just snug them into place.
