Rust Prevention Magic?
Auggie56
12:16 AM
NW Ohio
Did anyone try this yet? It can be found on eBay with several going price differences.
Just buy it from ECS direct if you want to use it. Used it on my entire cars hardware (that would have been bare OE), including the exhaust pipes and mufflers to burn off/in. Only thing that has shown any rust so far is my steering box "big nut" that is right beside the exhaust pipe. Boeshield is another great, or possibly better rust preventative.
I wonder if theres a solution to prevent inside out rust? Eg: inner ,outer wheel well to quarter? They always seem to bleed at the spot welds. Even if there are no pin holes. And the seam sealers trap moisture.
just wondering.
Krown Rust Preventative.. similar to Fluid Shield but not as waxy. (BOTH ONLY AFTER PAINT IS DONE!!!)
I use it often. Guys that opt for a rebuild instead of a restoration, and have a rusty linkage,I wire wheel the linkage and apply RPM.
Around here we drag cars to the junkyard because the frames are cracked or have holes in them, not because the fasteners are rusted out.
These guys that wear gloves working on cars with a polished work surface... hard to take them seriously.
