Damn, you are a glutton for punnishment.
Lovin every minute of it.... How'd you like the fit of them panels? Did you have to widen out the deck lid filler panel?
Did you have any issues with the trunk floor and drops fitting? I am about to start a 69 Charger and just received about 4.5K in AMD metal. I started measuring the trunk floor and the new piece is about .5 inch shorter than the original, but has the back up angle that much to long. It looks like the flange should have been bent back farther and all would have been good. Also the drops are longer than the originals by about .5 inch. I've used AMD trunk floors in both of my RR's and they fit perfect. Just wondering if this is a Charger only problem or just this car?
What did you fill your roof to quarter seems with?
I put one coat of metal to metal on the bare metal to fill in the void prior to priming since I was short on warm weather to paint. I'll determine what to finish fill in the joint with in the spring.
Where did you get the paint for the grille? Do you have part numbers for them? Car is lookin great
Haven't had a whole lot of time with the holidays but I'm trying to get the suspension parts cleaned and powder coated to get it rolling again. Probably going to get her back on the rotisserie to paint the bottom. One of my strut rods looked like a ski so I tried a little fabrication. I made my version of adjustables. You do have to loosen the bushing nuts to adjust them but not the tapered end that goes into the lower control arm. They are 7/8" thick so I don't think they are going to bend. I'll have a little more than 1/2"of adj. either way. Let me know what you think...
Just bead blasted my dash, looks nice and solid had some light pitting on top from no coasters under the beer cans of the past. Filled them in with a skim coat should be in paint tomarrow. Anyone have vin tag restoration tips, or know where I can get a stencil for the chrysler logo and name?
