Shop plans finally coming together!
1KoolBee
11:29 AM
Northern ID
So after being “shopless” for over 10 years, the dream is back on track. Corners are in. Should have all the poles set by end of the week.
Awesome! Good luck!
I Put my pole garage up 30 years ago. Built allot cars in it.
I call it my " Dog House"
Good luck.
the best feeling is building cars in it while it rains and snows outside.
:thumbsup:
Good luck.
:thumbsup:
Thanks guys! Given that I live in North Idaho, the ability to build in the winter will be awesome!
Like 493 Mike said, think seriously about it. Talk to your concrete contractor about it as a lot of them are installing the tubing themselves now. Even if you don't hook the system up right now it will be there when you are ready. Good luck and have fun with it.
Agreed on the radiant floor heat. There is a company on the west coast called BlueRidge Company (blueridgecompany.com) that has great pricing and excellent customer service. They will design the system for you if you provide a floor plan, and then give you a bill of material for everything. I dealt with them on my house and also my shop and have very pleased with working with them. If you buy enough from them, the shipping is free.
It doesn't cost much to get the tubing in the floor...you can buy the expensive stuff later. On my shop, I put visqueen down, then 3" foamboard and stapled the tubing directly to the foamboard and then wire mesh on top of that and poured concrete. In the house, I attached the tubing to the wire mesh and had less insulation below the concrete. The wire mesh/tubing are pulled up mid concrete in the house....but the contractor did not cut the concrete. In the garage they cut the concrete because they knew the tubing was 4" down.
Thanks for the tip but funding this is a stretch for me since I’m hiring out the labor. I’ll probably put the $ into insulation and I’ll use the wood stove I never installed in my previous shop .
i went with lots of insulation and a gas hanging furnace. 100,000 btu. My shop is 24x40 with a 12 foot ceiling. I was told it was to big and would be inefficient. The themostat is set at 45. The heat is always on. When I go out it takes less than 10 minutes to warm up. I'm in the shop nearly every day. It didn't increase our gas bill by more than $50-$75 a month.
I have a Hot Dawg heater in my garage. To put one in the shop I’d have to trench a gas line over 100’ or install a propane tank. Maybe a future upgrade
So we’re setting poles right now. This 3 point cement mixer is real handy. One load sets one pole. Hydraulic top link makes dumping easy. Have to run the engine at idle to keep from spinning drum too fast.
This weeks progress, 18 poles set, 4 to go. 2-1/2 pallets of 80 lb bags. Good thing we had a couple 20 year olds working for us!! Frame out next week.
This week’s progress. All posts in and aligned perfect. Back wall sheeted. Post tops notched for Trusses. Trusses next week!
Boom! And just like that……trusses! 2 sections of purlins to go.
Framing and sheeting about done. Metal next week! Remembering with my first shop how nice it was to work on a car with everything laid out nice. And not having to play garage Tetris to get to everything! This one will be even better!
Why sheeting on a post frame build, I know it’s stronger and will hold better, is it required in your area?
Strength and to eliminate “rain” inside due to condensation. In the county here, the only inspections required are electrical and plumbing. Otherwise it’s the Wild West, especially on barns. The guy heading this effort is a Master Builder from Atlanta, he’s not shy about putting extra lumber where it counts and being precise on square and measurements . This thing is solid!
