It’s used by racers, it’s similar to concrete, often called “hard block.” A “street fill” is usually considered up to the bottom of the core plug holes. You may need extra oil cooling to make up for it. If you’re just drag racing most don’t bother. You can see elevated oil temps on the street, likely won’t notice if you don’t monitor before and after.Not familiar with block filler, I will need to research that. Did this affect the cooling?
Money & Effort well spent !Those certainium rods work well.. just pricey, repairing a good part —priceless!
Any extra I can buy?Those certainium rods work well.. just pricey, repairing a good part —priceless!
I’ll look, under what heading?Not here I used them at the mill, I have limited acess to them. There are some on eBay right now.
This is the method I use to repair cracks. The first hole on the end stops the crack, then keep pinning, and overlapping to remove the crack. The longest one I have repaired was around 17" long.
View attachment 1956398 View attachment 1956399
View attachment 1956400 View attachment 1956401
View attachment 1956397 View attachment 1956396
View attachment 1956402View attachment 1956403
View attachment 1956405 View attachment 1956406
That is the real deal Lock & Stitch stuff... Which it seems is no longer available to the public.... Hopefully that will change... Cause it was the best stuff....
Thank you, Jim you also...I knew you would either chime in or I was gonna drag you in buddy. Merry Christmas to you and your family Dave.
